RCU Forums - View Single Post - Fuel Tank placement question..
Old 11-27-2010 | 03:41 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Fuel Tank placement question..
ORIGINAL: jaka
Hi!'
Must ask! Why have the tank so low????
Mount it behind the engine instead on the same 8mm plywood plate that the engine is mounted on...You use a plywood mount???
The boat will be set up similar to this boat using a similar radial mount.
(photo courtesy of Hooty301)
