RCU Forums - View Single Post - Airbrush recommendations?
Old 11-27-2010 | 11:14 PM
  #42
RSEA's Avatar
RSEA
Default RE: Airbrush recommendations?
Tony,
I appreciate your information on these airbrushes.
From your experience what size air hose would I need and regulator/moister trap to run on this compressor below?
[link]http://www.amazon.com/Makita-MAC700-Big-Bore-Compressor/dp/B0001Q2VK0/ref=pd_sim_sbs_hi_1[/link]
Motor 2.0 HP
Pump Oil Lubricated
2.6 gallon holding tank
90 PSI 3.3cfm
40 PSI 3.8cfm
Max Pressure 130 PSI
Amps 12.4
Noise 80dB
18"x10"x22"
weight 52lbs (wow, kind of heavy.. only downside I guess)
Would one of these regulators work?
[link]http://www.tcpglobal.com/airbrushdepot/abfilter.aspx[/link]
That compressor has a 1/4 coupler on it. So, should I be getting a 1/4" hose with 1/8" fittings to go with it?
Compressor, airbrush w/cups & needles, regulator, hose.. Maybe a table clamp stand to hold the airbrush.. Anything else I am missing?
