ORIGINAL: jedijody
ORIGINAL: zoaartcc
I am going to build the GP Extra 300s and install the DLE20 in it. I want to use A123 Battery and have seen several say they are using it with two Diodes. Can you tell me what value diode you are placing in line to reduce the voltage to a safe level. Thanks for any advice.
Dan
1N4007
Yea, what he said. I bought 10 for 90 cents at my local electronics store and then bought a 6" extension, cut about an inch out of the red wire, soldered them in series and then put heat shrink tubing over it. Then all you have to do is connect it between the ignition and battery. It dropped the voltage to about 4.9v under a 500ma load on a 3/4 full A123 battery.
