If it was meI would try both. Ihave tried bothon my bud hull's and found that the X435 prop would get you up on the plan really quick butI lost a little top end, where the Y535 prop took a little more to get onto the plan but thenI had a little more speed down the straight.
Just make sure you balance the props before you put them on the boat and you should be fine
