RCU Forums - View Single Post - SuperTigre45
Thread: SuperTigre45
Old 11-29-2010 | 10:07 AM
Bax
Default RE: SuperTigre45
If the engine was running when it hit the ground, you could have a bent crank, a bent rod, or a bent/distorted something else. If you remove the piston/cylinder assembly from the engine and the crank will turn smoothly and the piston moves up and down the liner smoothly, you have a bent rod. Careful checking will tell you the exact difficulty.
