RCU Forums - View Single Post - One Turbine For Multiple Jets???
Old 11-29-2010 | 11:39 AM
David Searles
My Feedback: (49)
Default RE: One Turbine For Multiple Jets???
ORIGINAL: Duncan
I'm in the process of putting a model together that will share the supersport that is in my Bobcat. I have a spare ECU which i'll program with the same parameters as the current one. I have also bought new valves, thermocouple, mount etc, so it should be a quick easy job to swap the turbine itself over from model to model. I was going to put a new fuel pump in it as well, but wren's seem to take ages to learn a new fuel pump, so for now i'll just swap them over
Duncan,
The ECU is not just learning the fuel pump. it's also learning the installation. Each install is different in that the fuel runs might be of different length, fuel tanks different plumbing etc. Don't be surprised if the ECU takes more time to relearn or change some of it's parameters in the new install.
David S
