RE: OUTLAW from EXTREME FLIGHT
hi just read the post about the 6.6 volt life battery usage, i and many others in my club are using a123 1100 mah batteries with zero failure, its was probably just a bad servo, and if you were to attend any imac meet you would see that many use this same battery source without failure, and these are megabuck airplanes as well, i fly futaba and airtronics radios and use some hitec servos as well... servos fail and that sucks as all failures do..
