RCU Forums - View Single Post - Do larger props require higher pitches
Old 11-30-2010 | 12:15 AM
ameyam
Default RE: Do larger props require higher pitches
Yes, I will get a couple. Atlease a 16x8 or 17x8 (will decide when I place the order) and a 17x4/5 if its available.
I have a related question. I have a 15x5 MAS on a OS FS91SII on a Phoenix Topstar (same as UCD 60 and Flip). I use the airplane only for 3D. Earlier I haed problems with a 75 AX on it so I switched to the 91 but have flown it only once since then. I found that the airplane flies very slowly. Should I change my prop and if so which one?
Ameyam
