RCU Forums - View Single Post - 50size (700W)
Old 11-30-2010 | 02:34 PM
opjose's Avatar
opjose
Default RE: 50size (700W)
ORIGINAL: Switch_639
hey there... is 700W enough for 50size extra 330L for 3D flight?
Nope.
A 50 sized Extra will come in around 6-7 lbs or so.
Assuming 7.4lbs All Up Weight, then you would want 1110 watts or so.
Give 1110 watts @ 14.8v that's a 75A draw... so I'd go higher on the voltage to drop the amperage a bit.
745watts = 1 HP so your 700w estimate would result in a quite anemic .50 size plane.
A decent .46 AX is rated to about 1.7HP or a more realistic 1.5HP so 745w x 1.5 = 1117.5w which is in line with the above estimate.
And that's assuming a LIGHT plane... I have a .50 Extra 330S where I use a .75 Super Tigre engine, which I find to be a perfect combo for this plane.
FYI: I run 800-900 watts on my .32 sized Electric planes and about 700-800 watts on my .25 sized electric planes, which gives you a point of comparison.
This too corresponds to the equivalent engines.
