RCU Forums - View Single Post - Thrust Line?
Thread: Thrust Line?
Old 08-02-2003 | 11:13 PM
jettstarblue's Avatar
jettstarblue
Default Thrust Line?
The "thrust line" is the "imaginary" line at 90 degrees to the arc of the prop. If the prop has 2 degrees of right thrust, and down thrust then the thrust line would be 2 degrees off from the 90 degree in both directions. Does this help?
Jetts
