RCU Forums - View Single Post - Thrust Line?
Thread: Thrust Line?
Old 08-03-2003 | 04:36 PM
jettstarblue's Avatar
jettstarblue
Default Alrighty then
That's more like it.
Yes this is where you want the center of the engine's crankshaft to be. Make a mark 7/8" from the top, and that's where the center of the prop shaft will go. They should also tell you to mount it with some right thrust, and more than likely some down thrust-more so for high wingers.
Jetts
