RE: Yellow P-38 build thread
Yes I do add cloth if I see that the area needs strength....But I use the button head screw for example on the formers in the booms where they end at the gear door opening ............some times they loosen from handling at the very tips the pan head screws add strength there and also .........if done carefully it looks like rivets a nice touch to the plane.......then I grind the head of the screw to flatten them to look like a rivet......
