RE: MDS 48 mid-range issue
Earl, if I could hazard a guess, I'd say that somebody turned the LS needle in too far. The MDS LS needle has a blunt taper and if leaned too far will bellmouth the end of the spraybear. Then you get exactly what has been described here. When set in the ideal position the LS needle will be about 1/32nd" from the end of the spraybar at full throttle.
