Servo torque (physics question)
Square
You understand correctly, a 1:1 ratio at the arms in question will net equal travel at both ends.
Lengthening the control arm 1/4" past the 1:1 ratio will deliver about 20 degrees less surface deflection. This is a mechanical advantage. Less throw, a little faster and more Torque at the surface.
