RE: OS Pull Start Problem
No....no grease at all.
Many engines are designed so the starting shaft does not rotate once the engine starts. For those, OWBs work best dry. I clean mine with alcohol.
Your engine has the shaft spinning all the time, so a tiny bit of lube might help. You can try WD40 as Supertib suggests, but I use a single small drop of ATF (automatic transmission fluid.....the red stuff)
