RE: 30cc Edge 540 build
Bladebender
I live in Elyria about 30 minutes west of Cleveland.
I had a a couple hours free today so I decided to install fuel tank and lines. I just had to test it all out and make sure their were no leaks. I am impressed with the DLE30cc tons of power it will sling shot this plane through the air with ease. This is my first gas plane and love it, after I test ran everything no mess! I filled tank up about 3/4 and it ran for 23minutes while I slowly worked throttle. I also tested out a Life battery from EPbuddy.comwith the ignition system. It is light weight and well made 2300Mah 6.6v. It was fully charged before I fired the DLE up. After 23 minutes of run time it only required 503Mah to put it back to a full charge. Looks likeatleast3-4flights on one charge. Using a cell pro10 itonly takes15-20 minutes from dead to full. It was only 26.99 may get another to power the reciver.Heres a pic of what I did today, feel free to include your 2 cents if you guys see somthing you dont like or any ideas that may or may not be helpful! Thanks
