RCU Forums - View Single Post - TWO A123's directly into Batshare into Receiver no problem?
Old 12-02-2010 | 08:17 PM
furloughed ual's Avatar
furloughed ual
My Feedback: (31)
Default RE: TWO A123's directly into Batshare into Receiver no problem?
ORIGINAL: rcjetsaok
Sounds good to me !!!! I'm gonna switch this winter and already planned to use Battshare. I am wanting to use this set-up w/ my current JR Charge switches, but I understand there are issues with that because of common grounds ??[sm=confused.gif] I was told I need to switch my charge switchs to the the Ultra-Switch Nano or equivilant that is a DPDT switch the opens negetive side as well when turned off... Does that make any sense, or do I understand that right? Is that an issue?
Lost.....
Danno
Yep...u are talking about a common negatinve ground....MOST chargers will not handle that setup...I recently switched all my switches to the Electroteck rocker switches....solved all the charging issues related to the common ground issue.
