RCU Forums - View Single Post - So why is it that.....
Old 12-03-2010 | 05:55 AM
Thomas46
Default RE: So why is it that.....
It is a difference if you are talking about Boxer or In-line engine.
Boxer (Flat twin) 2-Stroke engines uses the same Crankhousing room. So it makes no sense to use 2 carbs. One is enough.
In-Line 2-Stroke engines have single crank house space. Both chambers are seperated by the middle bearing with seal ring.
Here you can use 2 carbs. But mainly the manufacturers uses Y- intake header. Cheaper, but there is space for some tuning.
