RCU Forums - View Single Post - Small bug in new AF 5.5
Old 12-04-2010 | 04:56 PM
opjose's Avatar
opjose
Default Small bug in new AF 5.5
I'm loving Aerofly 5.5.001
However there's a bug in the on-screen display window that shows you things like smoke and dual rates.
If you turn on smoke the indicator shows that smoke is on ( as well as the plane producing smoke... )
If you turn on dual rates, the indicator never changes, but dual rates DO go active on the plane.
It's not a showstopper, as dual rates actually does work fine, only the indicator fails... Rajul could you alert the developers?
Thanks.
