RCU Forums - View Single Post - need help for historical reference
Old 12-04-2010 | 09:43 PM
torpedochief's Avatar
torpedochief
Default RE: need help for historical reference
Hey Pang,
To really convert to a Late Model Tiger, you need to notch the front area where the tow shackles are. The smoke launchers have to go. Late Tigers had only 1 headlight in the center of the front.
On the rear the tool box needs to go. And if you get really picky the adapter plate must be modified. Also in the picky picky area is the rear engine cover has to be modified with a triangular cover. The air cleaner intake is replaced with an armored cover.
On the turret there are three posts for use of a portable jib crane. The ventilator is moved to the center. In it's place goes a close in self defense launcher. And you need a turret protection ring, and cut of the bottom of the hinge for the escape hatch.
You need to add C hooks to the upper hull and on the rear left.
Then you need to move the tools around. I'll get yous some more pictures.
None of the above takes away from your fine job, however I can tell you are a guy who wants his tank to look the part.
Don
ID:	1530409   Click image for larger version
ID:	1530410   Click image for larger version
