RCU Forums - View Single Post - Grass shavings inside engine?
Old 12-05-2010 | 05:27 AM
ameyam
Default RE: Grass shavings inside engine?
OK, pictures are attached. This is the Topstar with the FS91SII. Its similar to the UCD 60 or flip 3D. It a veteran airplane. You can see the carb inlet behind the cylinder block. I have included a picture with the cowl fitted
The last one is from a couple of years ago
Ameyam
ID:	1530463   Click image for larger version
ID:	1530464   Click image for larger version
ID:	1530465   Click image for larger version
ID:	1530466   Click image for larger version
