RCU Forums - View Single Post - Fox Composite Typhoon
Old 12-05-2010 | 05:44 AM
lozza1965
Default RE: Fox Composite Typhoon
At last starting to make progress, boring stuff cleaned up the old hinges ready for the new ones, will be using 4.5mm Robart hinges
Servo mounts finally arrived Jr 8411 for elevators and Hyperions on other flight controls
Right the pain in the ass was always going to be the wings and associated bits, fuz should be very straight forward, the retracts only just fit or so i thought, turns out the doors
won't close with the leg retracted, so i've cut out a recess and will cover in due course
Ignore the elastic band thats part of the research and development program , how to get the door to open with the leg in such a small space, so that its in the right place when open and closed, anyway rather than try to explain after many many attempts got it sorted, now just got to make the assembly fit together in a proper professional looking way that works,
hopefully the pictures will sort of explain
Also the F16 is now finnished awaiting a test flight
lozza
