RE: Precision Aerobatics Addiction X Video & Photos
I'm kinda like DLWrcm. I'm not unhappy but for what you pay the quality could have been a lot better. The CF landing gear does not fit. It has to be cut down. One of my ant-rotation pins in the wing was loose and the other one was inside the wing. The engine box would not fit at all. Had to really work to get it to fit. The CF pins that go inside the fuse to help hold the engine box on were really loose. There was a gap between the pins and the bulkhead. Not really sure what good they are. I could not get the rear stab to seat all the way back in the fuse. Had to cut and sand just to get it there and then it was not parallel to the wing. I was missing the smaller hinges for the rudder. I also ordered a Dubro Micro pull-pull system. No major issues just a lot of small ones.
