ORIGINAL: T3beatz
Yes, its 14'' from the back of the tunnel to the opening, and yes you can set up for front or rear dump, as long as the front dump exits in front of the front opening, if not you will have to cut into the F1 former and you will have about 3'' of wiggle room there until you hit the landing gear mount. With little skill you should be able to make it work either way, with little to no mods necessary.
Perfect! A KS 86 rear dump is 14" overall including the inlet and the front dump is 12" so either would work fine. All I need now is an approximate measurement for header drop to know which header to get for the DLE 55. Still keeping the fingers crossed they have one of these left for me in a couple weeks when I can pull the trigger.Thanks for all the info, it is much appreciated.
Bandit
