RCU Forums - View Single Post - Engine Problem on Nexstar (Caused crash)
Old 12-06-2010 | 05:15 AM
  #32
bruce88123
Default RE: Engine Problem on Nexstar (Caused crash)
And when Opjose says "you should check the engine mounting screws" he means the screws that hold the engine to the mount and the screws that hold the mount to the plane if applicable. Some planes just use hardwood beams or other means permanently attached to the plane. There you would check for deterioration of the material.
