RCU Forums - View Single Post - CEN CT4
Thread: CEN CT4
Old 12-06-2010 | 12:42 PM
Dohcser
Default CEN CT4
I have a CT4 that I used leisurely, I have not used it in about 1 year due to an issue with the "drivetrain". I had it stored properly and the engine still starts, however when I try to drive the vehicle it will do maybe 5mph tops. I checked the clutch and 2-speed trans and to me (armature) it looks ok, however I ran it yesterday for less than a minute and noticed that the area where the 2-speed clutch is located was smoking a little.
I had adjusted this clutch per the specs of 4 turns out from all the way in......
Think someone can assist with what else might be causing the issue?
Also where can I find CT4 parts such as clutches, any reputable stores you are aware of?
