RE: HPP-21 Overload
Hi Brendan, Thanks for the reply. I am using HS5085 servos in a Vector 3 moulded aerobatic glider (2.3 metre span) on ailerons (1 each side) I am also using HS5245s on the flaps (1 each) and elevator. I have heard reports that some 5085s have overloaded and burnt out (it's one thing for that to happen on the ground and quite another for it to happen in the air!!! ).
So I was hoping that by enabling Overload Protection that I could reduce/eliminate the possibility of this happening and if so, what value to use?
