RCU Forums - View Single Post - Skyshark Stuka E-Conversion...
Old 08-10-2003 | 09:03 AM
Henke Torphammar's Avatar
Henke Torphammar
Default Skyshark Stuka E-Conversion...
Hi
if you loose the gearbox youŽll probably loose half of the power too.... not by lowering the input watts but by lowering the eff.
I wouldŽt use a mega 22/XX "inrunner" for direct drive, unless it is a very fast plane.
If you want a quitet gearbox you need one of the more expensive ones, for ex the Mega planetary (large black one)should be as quiet as the maxxon ones fitted on a Hackers, or maybe a belt drive ?!
hope this helps
