ORIGINAL: Da ROOK
HOWDIE JET JOCKS,
Got a smoke system setup in My Flash and since there is no access to plumbing and nozzle (under wings) I am not able to put a shutoff valve inline unless I route the output line all the way to front and back in order to stop leaking when I fill the tanks. Any Ideas? thanks
the setup is:
two 18 oz round tanks setup in series in fuse above the wing near the turbine. Sullivan pump above the turbine with crap trap on input and one check valve on the output.
ALso need some radio setup ideas on JR 12X. main switch and mix ideas to throttle, other switches, etc...?
thanks
jason
Here is what I did on mine.
I have Tams Smoke System.
My fill Line is T'd.. 1 line to the Tanks and the other to the in on the pump...The out of the pump goes to one side of the shut off, then the other side of the shut off to the nozzles. When I fill I keep the shut off closed and nothing leaks. After engine has started I open my smoke shut off.
I have mine on a switch and the throttle controls the amount of smoke.
Here are the directions from the Tams Sytem
