RE: will the wing really break???!!!!!
I have not seen anyone flying these with retracts. If you don't like the fixed gear, just put the skid plates on it and hand toss it. It flies like a dream, don't ruin that by adding a bunch of weight. Plus you have to add a retract servo...yada yada yada. When you start carving that wing out, it should be fairly obvious that you are removing structural material. The wing must support up to 5 or 6 times the weight of the entire aircraft once airborne and you start putting it into high G maneuvers.
Good luck.
