RCU Forums - View Single Post - Smoke System Setup in C-ARF FLASH
Old 12-08-2010 | 08:59 PM
AFTERBURNER1's Avatar
AFTERBURNER1
My Feedback: (80)
Default RE: Smoke System Setup in C-ARF FLASH
ORIGINAL: Da ROOK
Dougie/jim,
thats where I have it now.. left slideer.. but I was thinkin of mixing it with throttle halft to full. but I definitely setup for low to high.. are you guys running your pumps on 6 volts?
DD,
Hows plumbing set up in your flash? your tanks in front? how does it not leak?
KC/DDL,
check valve will not stop it from dripping. works the other way. also I have set it with third fill line, however, apparantly the resistance of the two tanks through the vent is higher than the pump to nozzle, therefore it drips when I am filling the tanks. Thats what I am concerned about.
I can only think of two options bad options:
1) route the outlet to front and put a valve there and back to nozzle, this will create major delay in the smoke on off.
2) Put an orifice i the outlet to increase the pressure to above the pressure required for filling the tank. in that case i think the pump is going to work hard and may not have enough output.
unless, somebody has a better idea. I also dont want to try any facny ideas like remote valve....
Jason
You are losing WAAAAAAAAAAAAAAAAAAAAAAAAAAAy too much sleep over this... Left slider, finger mixing, 40oz, 7.4v 5200 Fromeco pack, on/off valve and off you go!!!
