RE: Comp ARF BAE Hawk build thread
phil question.. are you loosing air when the plane is turned off or when you have the system on with the gear retracted. i am loosing air when i retract the gear. its a cylinder leak on mine. i am putting the bigger cylinders on so that should fix that problem.. air systems can be a pain..
