RCU Forums - View Single Post - Flat Clear Spray??
Old 12-09-2010 | 02:00 PM
FalconWings's Avatar
FalconWings
My Feedback: (57)
Default RE: Flat Clear Spray??
ORIGINAL: YellowAircraft
Hi,
For those of you who use rattle-can paint, what's a good flat clear? I used to use Top Flite Lustrekote flat clear, but around 2005, they must have changed the formula because it's just not flat anymore. In fact, it's just a cloudier semi-gloss. Does anyone know of a good rattle-can alternative for small projects? TIA
use whatever clearcoat you can find and works better for you and amke sure you put enough to protect your decals. Then do an 800 grit wet sand. You can get it as flat as you want.
I ahev an F-16 that's dead flat, and though it looks very scale like, cleaning it is a pain. If you stain it with your fingers, they will remain there. for a while.
David
