RE: ZIROLI SBD DAUNTLESS BUILD
Center wing (cont)
pic 1/2:
1/32" ply flap support. 1/8"X1/4" balsa stringer and last spruce spar epoxied to the center wing.
pic 3:
Dry fit the flap.
pic 4/5:
The wing support balsa blocks were epoxied to the wing mounts (one mount off by one rib so I had to make a new one and epoxy it in the correct location on the right side in the picture).
The wing is set up with one bolt at the front and two at the rear versus the traditional dowel in the front.
pic 6:
Wing tube supports and wing bolt supports epoxied to ribs.
pic 7:
some paint mask brown paper used for the servo wire guide tubes with CA added.
pic 8:
One set of 4 sheets and two sets of 2 sheets glued together to cover the top of the center wing.
NOTE: until the web site is fixed, just click on the first picture and it will come up 'normal' size and then sequence through the pictures.
