RCU Forums - View Single Post - General port timing guidelines?
Old 12-10-2010 | 06:27 AM
Nosedragger
Default RE: General port timing guidelines?
a lot of guys do that to make timing changes with out commiting the cylinder to permanent changes.You can change intake timing also using this approach although on the exhaust side you are limited to amount of change you can get because the width of the land between ring and crown.You probably could get a few degrees though.
