ORIGINAL: extra 300
David,
Do you mean to say that you can use a twin components glossy clearcoat and still turn it flat by doing a 800 grit wet sand??
Thanks regards,
Yes sir. I think a lot of Pros actually use this technique.
I just wet sanded my bandit which had a high solids PPG Clear on it (high gloss) and it looks dead flat now, but slick enough to allow for a good wipe down if needed.
On my next scale jet I will use this technique vs the flex n flat agent, which makes the model dead flat but impossible to clean.
David
