RCU Forums - View Single Post - Beginner kit...no experience
Old 12-10-2010 | 12:38 PM
shd3920
Default RE: Beginner kit...no experience
I highly recommend the PT-40 http://www3.towerhobbies.com/cgi-bin...?&I=LXJ557&P=7
It is so extremely easy to build, and the manual is very well written and detailed. The kit practically builds itself with self-aligning parts. The wing and fuselage are designed to hold itself together without glue which makes the building easier. You assemble the wing and fuselage without glue, holding the pieces together with rubber bands, and then when the entire structure is assemble you apply CA glue to all the joints.
Check out the manual and see just how easy it is . . .
http://manuals.hobbico.com/gpm/gpma0...anual-v1_2.pdf
