RE: Sebart Wind S Pro
I made the same observation as you concerning the need for hinge supports and put them on every hinge where none were supplied. I made the supports using 1/8" end-grain balsa/carbon fiber laminate; drilled/reamed to accept the hinge fully up to the moving part. A fuzzy image is attached - best I could capture.
Andre Bouchard
