ORIGINAL: DelGatoGrande
ORIGINAL: Bob Toilet
Jeremy it would be great!
as you know already i have paint a few jets with them and dont like them at all
Water base paints suck big time cause they take ages to dry and if you are not carefull they will driple ...
we change over to them a few years back (inviroment reasons )
...start the tutorial!!
Then you are doing it all wrong! I work as a Car painter, and have used both the PPG Enviro base, and the 90 series from Glasurit for a few years now. It do not take long to dry. Just remember: it is not warm temp that makes the water base dry, but air circulation. And if you make the water base driple, you are putting on way to much!
Christian
i hope i do it wrong and there is an easy way for them
as for too much ...some
white jobs i did tok 4 coats to ''cover'' corectly and show the collor[:'(]
Christian is correct, if you are getting drips or runs it's going on way to thick and not allowing to cure between coats. I'll be sure to go over all that when I do the tutorial.
