RCU Forums - View Single Post - GP Extra 300S 60 Build 2010
Old 12-11-2010 | 03:35 PM
  #50
mesaflyer
Default RE: GP Extra 300S 60 Build 2010
SeamusG,
I started this kit a few weeks ago. I'm at the point of starting on the fuse. I only use Titebond so I build a little slow. I did the tail mods a little different than others. Will be installing a DLE 20, so the rud/ele servos will be mounted in the rear side of the fuse. The elevators will be tied together with wire, so only need one servo. Just finished up the wing. One area I did not care for was the beveled hinge blocks that fit between the two TE pieces on the wing, but it's done. I also installed the hinge blocks before I installed the top TE sheeting. Figured it would be easier to get to it that way. Have subscribed to your thread, keep up the good work.
