RE: Weird nitro problem
i helped a kid brake in a .15 engine from a nitro sport. he was going to kill it if i wasnt there (way lean)
i blame it on user error.
check/ replace fule lines, check tank, remove and check glow-plug, replace it as they foul very quickly after break in, there are two bogging sounds a engine will make one is a deeper almost gurgle, one is almost like it cuts out, typically the gurgle is caused by the high speed being too rich, the cut is from too lean a high speed setting or low speed being too lean.
once you replace glow-plug, glow plug igniter battery, and lines, start it up then quickly pick up the car, and revv the engine, a medium cloud of smoke should pour out, and have just a slight hesitation, followed by a very rapid and fast rev, if not, adjust the high speed, if it starts to rev quickly then bogs, with little smoke, richen it up with 1/4 turns counter clockwise, revving it up each time. if it bogs a long time with thick smoke and revs high, it is to rich, lean it by turning 1/4 turn clockwise.
once you get that set, now its time for the low speed, adust the idle set screw at manufacture specs, or slightly higher for this adjustment, if the car burbles and wants to die and with acceleration it either stalls or it bogs then clears up it is running rich, turn it in 1/8 turn clockwise, each time blipping the throttle, get it to a nice steady idle. if it revvs high and wants to die, and if you blip it it either stalls, or it takes off then bogs it is running lean, richen the low speed needle 1/8 at a time, blipping each time.
once you get it to idle, now get it warm by taking quick passes, it should have a nice light smoke trail and should provide decent acceleration and good top end, if not and it produces low amounts of smoke and wants to stall at high rpms, richen it up 1/16 - 1/8 counter clockwise, if it produces alot of smoke and not much acceleration, lean it out 1/16 - 1/8 at a time clockwise.
once you have that sorted out, make a few passes, and bring pinch the fule line, it should rev up within a second and die under 5, if it takes too long to die, lean the low speed needle 1/16 clockwise at a time, if it dies very quickly, richen the low speed needle 1/16 counter clockwise at a time
and there you have it, a well running engine!
