RE: 2 Servo Mechancial Retracts
Information can be either positive or negative. The retracts are already installed in this aircraft, they are OEM. The plane in question WM P-47D 1/6 scale. The overall weight of the plane fully loaded should between 11-13 lbs. Due to the weight factor I wanted to install pneumatic retracts but this will entail extensive modification.
