RE: Determining the Max battery for an ESC
22M-1000 Motor;
Input Voltage: 7.2-12V
kV Rating: 1000rpm/V
Max. Constant Current: 11A
Max Surge Current: 15A
No Load Current: .65A
Internal Resistance: 235 milli-ohms
Ball bearings: Two, shielded
Motor Diameter and Length: 1.1" x 1.14" (28mmx29mm)
Shaft Diameter and Length: .16" x 1.73" (4mmx44mm)
Total Weight (VPP and Motor): 2.1oz (59.5g)
Length prop tip to tip is approx. 10"
