RE: What is the problem????
Thanks for the replys guys
Today I will try it again.
I charged up my field box because the starter ran the battery down.
I pulled off the cowl
I am trying to start it in my basement. (once the wife leaves for work)..... Warm in the basement
I will start with the high needle 2 1/2 turns out
The low 2 turns out. Hope that will work
1 question that I have never seen on my other glow motors is the High speed needle is remote and in the rear of the motor. The low is over the carberator. I can see in the carb as I ajust the needle. I screwed the needle all the way in and the needle ran out of threads..... Hope you understand that?? In other words, the needle never gets tight. I needed a needle nose pliers to lift up on the needle to get it to rethread. MMMMMM
Any Ideas??
Thanks again guys
Hoss
