Help sheeting a fuse
Hi all- I'm having a tough time sheeting the top of my Top Flight DC-3 Fuselage. I'm trying to wrap 3/32 balsa sheeting over the curved surface. The structure consists of several formers and stringers. I did one section already and in order to get the balsa to curve, I had to wet it quite a bit. Once wet, I was able to curve the sheet OK, however I found the next day after everything dried, the balsa must have shrunk (or it expanded too much when wet) resulting in a faceted surface. Rather than a smooth "C" shaped surface, the sheet now is slightly flat between the stringers. Any suggestions before I move on to the next section? Thanks.
