RCU Forums - View Single Post - Guide to breaking in brushed motors
Old 12-14-2010 | 03:39 PM
shenlonco's Avatar
shenlonco
Default RE: Guide to breaking in brushed motors
Yep like panther said... You can take it one step further but i don't think it's needed to much for tanks but it does give motors more power and RPM ... You run the motor under water...Yes under water on low voltage 2 to 3V for a few min and it will break in perfectly ...under water makes the brushes seat much faster to the com and its cooler and no arking to foul the com during break in.... the minerals in the water help to seat the brushes fast so only put it in for a few min no longer than Five i would say.
Then shake it out let it dry in a warm place and re oil the bushings and your set. NEVER HEAT THE MOTOR AS HEAT WEAKENS MAGNETS!!
I did this for slot car racing and it worked great also on sme brushed RC motors as well.
