RE: Are Ball Bearings Worth It?
i use the standard bearings available in the kits, and i replace the bushings in the steering with yeah racing ones from rcmart. I think that all RC's must come stock with a full set of ball bearing and no stupid plastic or bronze bushings. You will be suprised how much more steering you can get from replacing the bushings on your tamiya ta05 or tb03 to ball bearings, certaily helps on tight tracks.
