Help on E SKY servo connections
I recently acquired an ESKY Belt helicopter. My first one. It was used and needed a couple things, like a speed controller and linkages. I got it all together, but i'm not sure what channel to plug all the servos into. I had no manual with it, so i found one on the web. It tells me that the aileron should be plugged into ch 1, the elevator into 2, the throttle into 3 and rudder into 4. The first problem is i don't really know which is aileron and which is elevator. The second problem is i have an extra servo, and a gyro. Where are those plugged in? There are 6 channels available. The rudder is easy enough. There are two servos mounted side by side on the rear side of the swash plate, and one on the front.
I assume that if everything is on, and in neutral position, the swash plate should be level?
Transmitter is 0406A, and receiver is EK2-0420A.
Thanks.
