RCU Forums - View Single Post - Why did my engine shutdown inflight
Old 12-16-2010 | 03:18 AM
BaldEagel's Avatar
BaldEagel
Default RE: Why did my engine shutdown inflight
Does your ECU have different indications for shut down? "Fail Safe" "Rx off" "Normal" or "Low Trim" or some such, the difference between fail safe and a commanded shut down will certainly be indicated in the GSU screen for last shut down, at least that way you could eliminate the Radio gear and look to the turbine installation.
Mike
