RE: JC 60cc Engine
OK guys,
First run:
Started right up with the needles left as they where.
High end was way lean, and had to be turned almost an entire turn out.
set the lowend as soon as the engine was warm and let it run for +- 10 minutes at 2000RPM just to get it used to it.
Nr's that I have seen so far are 6350RPM high end after 12 minutes of running with the high end not set properly.
So far nothing has fallen of or broke.
I will let it sit at 2-2500RPM for a while and set the high end to top and report back soon.
Regards
Andreas
